Error 9401 bizhub 36 42 C35
  • Ros.g
    • 6
    [Error Code] Error 9401 bizhub 36 42 C35
    Hello, I solved the problem of the lamps of the 'scanner unit bizhub 36-42 - C35 and do not need to replace everything. The lamp is equal to the Triumph-adler DC-2128 "code : 302H994260" - orders two and modify the length of the cable on one of the two.
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Error 9401 bizhub 36 42 C35
    Why not just use the cable on the old lamp?
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • Ros.g
      • 6
      • Ros.g
        • 6
        hello, now no longer need to do this because it is available parts.
