c280 "warming up" will not print or receive faxes (intermittent)
  • andyf424
    • Jun 2013
    • 126
    Customer of mine has a c280 that occasionally gets stuck "warming up". When they arrive in the AM, the machine is in powersaving mode. If they try to print, scan, fax, whatever, it wakes up and shows warming up indefinitely and after 30 minutes to an hour they'll power cycle it and it'll be fine. While the machine is stuck warming up, they can not receive faxes and they can't print because the machine shows offline. In the AM is when they receive customer PO's so they are concerned that in the morning, if nobody checks on it and turns it on/off, faxes aren't going through.
    Of course, this is intermittent and I have never been able to witness it. I have updated firmware to the newest version (g00-d2), combed SSD for solutions, I also reset all memory dimms/simms and MFPboard connectors. Any of you folks encountered this in the field? Any input is appreciated.
    As of now, I left the call open and they'll call me if it happens again so maybe, just maybe, I can catch it in the act.
  • andyf424
    • Jun 2013
    • 126
    Re: c280 "warming up" will not print or receive faxes (intermittent)
    Got a little more info, windows work stations show the printer being in an "error state" not offline. Also MML shows 0 trouble codes and no oil cans.
    • andyf424
      • Jun 2013
      • 126
      rewrote firmware, switched to 100 duplex vs. gigabit and am asking customer not press the power button on the side of the machine at night. We'll see what happens, they'll call me if it does it again.
      • stevena86
        • Oct 2012
        • 130
        Check the power save settings in admin mode. I've heard from a few techs I work with that if it is in Low-Power Mode that can cause some strange issues. Set it to sleep mode and see if that has any affect.
        • habik
          • 2013
          You are I think on a right path. I had similar when some one was printing "Remotly" through VPN and his internet was sluggish and it was just hanging and hanging..If I remeber correctly his laptop was casuing this issue, but They could see it that a job was coming through, a.e Blue light Flashing Flashing but machine was not responding, just never arrived. Even when I rebooted the machine it eventually came back. So What I did was disconnected the Fax Line, still flashing. Reboot with Network cable only, still flashing. Reboot without any network or fax line connection. Flashing stopped. So Network it was. Cleared all the queues in their entire office. Still flashing. Asked if ANY one else is hooked to their network, hmmm actually and the rest of the story was remote connection print queue..
          Good Luck.
          Firmwares HERE
          • andyf424
            • Jun 2013
            • 126
            Customer called this morning, problem is back. Rebooted and now runs fine. I'll try the power settings in admin.
            • JustManuals
              • Jan 2006
              • 9838
              This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
              Paul@justmanuals.com
              • andyf424
                • Jun 2013
                • 126
                Administrator>system settings>power save settings are as follows now
                low power mode settings = 240 min.
                Sleep mode settings = 240 min.
                Power save key = sleep
                enter power save mode = normal
                well see how this works. I'll update when I know more.
                • andyf424
                  • Jun 2013
                  • 126
                  It's been a week..... Fingers crossed!
                  • stevena86
                    • Oct 2012
                    • 130
                    Hope that fixed it for ya.
                    • grimreeper
                      • Apr 2014
                      • 12
                      The firmware and solution rom should have A0ED0Y0-F000-GJ4-D2-300-CHECKSUM-88C9.docfixed this but you say when the machine recieves a print job it does this it could be that the machine is recieving a corupt data packet if you can change the IP address of the machine and see if still does this because whatever corupt data packet there is will no longer be routed to your machine I have ahd this on other MFP's that either restarts automatically or just becomes non responsive. Please check the attachment regarding the firmware upgrade. Good luck.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        Originally posted by grimreeper
                        The firmware and solution rom should have [ATTACH]24702[/ATTACH]fixed this but you say when the machine recieves a print job it does this it could be that the machine is receiving a corrupt data packet if you can change the IP address of the machine and see if still does this because whatever corupt data packet there is will no longer be routed to your machine I have ahd this on other MFP's that either restarts automatically or just becomes non responsive. Please check the attachment regarding the firmware upgrade. Good luck.
                        thats why i always suggest copier is install on a server. otherwise you can get a random pc with local installation constantly sending it corrupted data and end up having to do a packet capture to figure out which PC its coming from
