BIZHUB PRO C6500 error code c-3801
  • impimp329
    • Aug 2010
    • 55
    I just got this machine a couple of weeks ago and it had just been serviced by Konica when it was at the previous owner's shop.
    I noticed an error code as I was trying to get a rush job out. Can anyone offer a quick solution as I need to get this project out today!!!!!
  • JustManuals
    • Jan 2006
    • 9838
    Re: BIZHUB PRO C6500 error code c-3801
    This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
    Paul@justmanuals.com
    • Tech80
      • Jan 2013
      • 6
      This is a under temp code from Temp sensor 1 (TEMS/1). You should check your thermistor, clean it. Then you have to reset the code.
      To reset: Go to DipSW 3-1 and set to 0.
      You may have a bad sensor or heat lamp.
      Hope this helps.
      • jmv
        maybe the bearing is off the fuser rollers
        i have this probleme and i replace bearing the fuser roller 1
