C350 Scan to Email
  • luggie34
    • Aug 2011
    • 11
    C350 Scan to Email
    Can someone point me to a thread or instructions for scan to email setup for bizhub c350? I using gmail to email from.
    • 14815
    Re: C350 Scan to Email
    I am pretty sure this machine is not capable of SSL email, so that means you can't set it up for gmail.
    • luggie34
      • Aug 2011
      • 11
      What are my other options? The SMTP Server has four fields and is asking for an IP address.
      • darry1322
        • Oct 2010
        • 817
        Those fields are for the IP address of the SMTP server. You'll need to either find an SMTP server which requires no authentication and no security protocols they can use or set up a local SMTP relay for them.
        • luggie34
          • Aug 2011
          • 11
          Thanks, thats more than I can chew off. I will call in someone.
          • darry1322
            • Oct 2010
            • 817
            I've had a couple of C350s that change their ISP and had to move to scan to FTP.
