konica 7222 not print function
  • wiedu
    • May 2011
    • 47
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: konica 7222 not print function
    I would like to help but I think something was lost in the translation?
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • wiedu
      • May 2011
      • 47
      We controle IP-432 has 2 photocopiers from konica in 7222 with printer.
      we have print test below(at the bottom) windos 7.problem is only of one photocopier print funtion leave test Windows.
      Other photocopier also konica in 7222 with IP-432 print no test Windows???
      I already have around do not dip other IP-432, however, also function??
      ask, man already know problem??
      Problem of device(appliance)??
      we thanks nicely for everybody heffen
      • mrwho
        Major Asshole!
        • 4299
        If I got it right, he has two machines, one prints fine and the other doesn't.
        Both printing via USB?
        Maybe a defective controller? We need more details - if you try to print via network, does it work? Are you able to access the controller menus on the non-printing machine?
        If you swap the machines, does the fault move with the machine?
        Mascan42
        Ibid
        • wiedu
          • May 2011
          • 47
          Yes, You are right . I to connect network
          printer controler work, I have printed menu controle IP 432.
          I will try again later to check
          When I print copier function say for you.
          I thank you for your hiffe
