C6501: Black vs Color developing unit
  • mrwho
    Major Asshole!
    • 4299
    Hello there.
    I need to replace a black unit, but I only have color units at hand right now. I've checked the parts manual, but the only different part number is the unit itself - all the other parts share the same number.
    So, what's the difference between those two? Can they even be swapped, if just for a while?
    Mascan42
    Ibid
    • 15068
    Re: C6501: Black vs Color developing unit
    Sorry didn't read the title
    • raulblanco
      • Apr 2014
      • 8
      Hi
      I once exchanged a color unit for black to identify a problem, blocking the entrance of toner unit and it has worked only for a copy from the service mode. I would not put a color unit with the developer and he would do the black toner density because you may be error, the part number is different therefore would not let her work well.
      • dljorg
        • Sep 2009
        • 93
        Our company swaps the color and black dev units all the time but....
        If a black unit has had toner in it and is not cleaned very well there is a potential contamination problem, especially with yellow.
        Color unit going to black should be fine.
