KMBH C353 C2151 code retraction error on secondary transfer roller
  • Desert Rat
    • May 2008
    • 1089
    This is an intermittent problem. A friend of mine has replaced the transfer roller but that did not help.
    I took the assembly off the door and cleaned the sensor. That lasted about 2 weeks.
    I am having trouble finding a parts break down in the parts book. I'm looking for the secondary transfer
    roller retraction motor and/or sensor. Page 36 shows the best picture but the part is not listed. The picture
    shows that part of the door in a box with dash lines around it and the letter "E".
    What does that mean? Will I have to get the whole vertical transport? I was hoping to at least get
    a number for the motor assembly.
    I can feel it working when I make a copy, but no codes appear when I'm there, naturally.
    What gives? Has anyone else had this code before?
    DR
  • emujo
    • Jun 2009
    • 3009
    Re: KMBH C353 C2151 code retraction error on secondary transfer roller
    There was a bulletin from KM about this problem years ago, but since the model is considered obsolete, it has been removed, and/or archived. I no longer can find it. It dealt with a change to the assembly, maybe someone can find and repost for you. Emujo
    • Ste Scott
      Not Sure if you still have this Problem but I also had it.
      I messed about changing various parts on the right hand door but still kept coming back .
      in the end I noticed you could order the complete right hand door,so I did and fitted that.ive not seen the error since and this was a good 3 months ago.
      its a bit of a pain to replace but certainly fixed it :P
      • Desert Rat
        • May 2008
        • 1089
        Thank you both for the quick reply,
        Emujo, having that tech bulletin would be very nice. It reminds me that I have some
        solution bulletins that I can search through. Thanks for the memory jog.
        Ste Scott, I considered replacing the whole assembly also. Looks expensive, and that
        may be my stumbling block. But I will price it out or look for a parts unit.
        Thanks again
        DR
