Konica 7020 Error Code F-14-11?
  • tmcit
    I have a 7020 with the error code F-14-11. Could someone tell me what that is?
    Also, where do you find these? I've looked in various manuals and can't find anything. Thanks!
  • mrwho
    Major Asshole!
    • 4299
    Re: Konica 7020 Error Code F-14-11?
    Look in the service manual, Field Service -> Diagrams -> List of Warning (Error) Codes.
    That error doesn't exist, though. Are you sure that's the correct error?
    Mascan42
    Ibid
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Sounds like a fuser code. soft sw 0 - bit 1 set to Off to reset I think.
      Machine so old you're better off rolling it off into the dumpster.
      • PeterG
        • Jul 2008
        • 177
        Switch 3- bit 1 to off actually.
        But your advice was sound, dump it.
        • mrwho
          Major Asshole!
          • 4299
          Fuser problems are F34, F35 and F36. F14 would sit somewhere between "communication abnormalities" and "feed and drum area abnormalities".
          But you two are right, send it to the dumpster.
          Mascan42
          Ibid
