KonicaMinolta C35 error code 9401
  • Destoned
    • Jul 2009
    • 24
    We believe this to be a lamp problem and I was wondering if someone else had found a replacement lamp for this unit, since through KM you must order the whole optical unit.
  • JR2ALTA
    • Feb 2010
    • 2031
    Re: KonicaMinolta C35 error code 9401
    No. But I wish things like this were spelled out in release bulletins.
    • Speedy
      • 30
      This is a common problem with this POS! Try cleaning the optics and there is a firmware patch for the scanner. If that doesn't fix the problem, the only thing left is to replace entire scanner.
      This model can't go away soon enough!
      • HoonBoy
        • May 2011
        • 130
        Nop... Biggest problem is that scanner lamp stays on all the time...if it's not in sleep mode...
        Make sure too put sleep time mode as low as customer allows...
