Bizhub Pro 5501
  • radu
    • Feb 2010
    • 18
    [Misc] Bizhub Pro 5501
    Dear firends,
    I've been checking this machine quite a few times by now, and it used to work fine until one day when it started to print
    like in the documents attached to this post. It's quite strange and I admit I haven't seen anything like this so far.
    I don't have the slightest ideea what it could be causing this image error.
    I can only say that:
    - no errors are coming - machine is printing or copying without any sort of error.
    - auto gamma sdjustments and calibration don't come with errors
    - testing the laser with state confirmation did not come NG. (the laser values from the bracodes labels are entered correctly in the LD area)
    - If I jam the process, the image is like this (like in the samples) when it reaches the transfer...
    - I have checked for visual damage on the harnesses and I did disconnect and reconnect most of the motherboard wires/laser with no impact on image output.
    The first 2 prints are from list output
    The last 2 from test pattern....
    Please if you have any ideea of what it could be ...let me know. Any help is appreciated!
    Thank you,
    Radu
  • jotunn
    • 618
    Re: Bizhub Pro 5501
    I would check Memory Control Board Assy or Image Processing Board Assy.
