SD-511 help
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 90
    SD-511 help
    I have Bizhub C224e machine with an FS534 and SD511. Set code C-1115, Center-staple knife drive motor malfunction. Cleared code, went into service mode to test motor and code sets immediately. Figuring motor has failed, removed SD unit and checked all connectors and reinstalled. Upon startup, got a "door open, please close" on finisher. Opened and closed door and it set a different code.( cannot recall number as I tried to clear right away). Now, machine will not even recognise finisher being installed. Support says replace PRCB board. Did that and FS board, and SD knife motor. Still, no finisher. Checked power supply and nothing. Replaced power supply, start up, see finisher. Have to update firmware since all boards are new. upon restart, no finisher again, no power to finisher. Going crazy trying to find the problem!!! I have new power supply on order and will power up without SD unit plugged in to see if finisher will install. Has anyone run into anything like this or know some specific things I should check? No rubbed wires but, something has to be dead shorted. Any help is appreciated!
  • stevena86
    • Oct 2012
    • 130
    Re: SD-511 help
    Check all your connectors on your finisher board. Do a continuity check on the wires from the board to the machine. Make sure those wires are plugged in.
