KM C6500
  • impimp329
    • Aug 2010
    • 55
    KM C6500
    I have been running my c6500 without much problems. Friday, the control panel was not responsive to touch. Shut down and unplugged machine. Started back up and no codes but panel is still not responding. I can't change paper settings or any other settings.
  • costel fasola
    • Jun 2010
    • 69
    Re: KM C6500
    Clean your touch ..u have dust into touch and display
    • RRodgers
      • Jun 2009
      • 1947
      Re: KM C6500
      Yeah, as suggested pull the screen off and clean it. I've seen stuff get stuck under the lip (were the screen meets the frame) and that causes them not work work.
      • impimp329
        • Aug 2010
        • 55
        Re: KM C6500
        I tried that and it still has no response. Should I just replace the panel?
        • RRodgers
          • Jun 2009
          • 1947
          Re: KM C6500
          For a hail mary you can try the ligjter trick. (Its on youtube)
          • acusso1234
            Tecnico
            • Dec 2008
            • 250
            Re: KM C6500
            Hi. You can use a usb mouse plugged in the hidden usb port. You can find it on the upper right side of the printer, under a little cover. In this way you'll get an arrow/cursor on the panel and can use it as a normal pc.
            ... In the minute that you're thinking of giving up, think about why you lasted so long ...
