Re: Bizhub 363 will not print from a PC
Try changing the NIC speed from Auto 10/100/1G to Auto 10/100 then reboot the machine. I have seen this many times if the NIC and switch both support 1G but all the cabling isn't cat5e or cat6 the data light will flash forever and no print jobs. It can be a simple as the patch cable at the copier or the switch is only cat5.
