BZ1200 error code 4705
  • Downunder
    • Aug 2007
    • 174
    BZ1200 - 6 million on clock. Intermittant code 4705 -- paper jams at registration unit. Have replaced motor, clutches, main boards, adu board, registration unit. jam code also indicates that paper was fed from tray 3 even though it was fed from another.
    Remove jam, turn off copier and then it will run for a while, sometimes even a day with no problems. Stock is good. Any suggestions would be appreciated. We are about to try nvrm next. Firmware up to date
  • fajdoooo
    • Jul 2014
    • 18
    Re: BZ1200 error code 4705
    Hello,
    did you found out vhat the problem was with the mashin? Thanks for your help.
    • tulintron
      • Jul 2014
      • 668
      C-4705 when feeding paper from PFU. J-1686 or J-1856 jam codes may also be indicated.
      CAUSE: PF exit conveyance sensor (PS24) is soiled, blocked or damaged.
      SOLUTION: Check for any debris/paper blocking the sensor. Clean the sensor and, if necessary, replace PS24 (p/n 13QA 8551 1).
      Description
      Intermittent C-4705.
      bizhub PRO 1200 Warm-up, wrong display, incorrect operation, lock-up
      CAUSE: The codeis described as a "Printer Time Out". In this case, an unexpected detection of the PF-703 Exit Conveyance sensor (PS24) generated the malfunction. The sensor may be dirty or damaged and an incorrect signal was sentto the PRCB.
      SOLUTION;Inspect the wiring for PS24 and clean or replace the sensor (p/n 13QA 8551 1).
