Bizhub B&W 350, + Faxkit. Networkfax?
  • Hansoon
    • Sep 2007
    • 3391
    In the old days there was something like Networkfax for the BH-350 equipped with the FK-503 faxkit. Cannot find the Networkfax software anymore on KonicaMinolta's website. Is it still around and does it work with W7?
    Hans
  • rrrohan
    • Sep 2011
    • 1977
    Do you mean the print driver that allows you to send a fax from PC to copier like it is a print job?
    • JR2ALTA
      • Feb 2010
      • 2033
      Re: Bizhub B&W 350, + Faxkit. Networkfax?
      You will have to find a copy of the CD which has the scanning software and network fax. I dont know if it will work with 7, sometimes I'm surprised at what does. If I remember it was not: hit print and pop-up for #, it had it's own weird, backward way of working.
      • rrrohan
        • Sep 2011
        • 1977
        I have a backup of the CD if you can't find your original
        • mo0651
          • 1054
          I don't think that series would network fax. The bh362 series 2 would do it. But only the series 2.
            • 14852
            The BH350 will network fax, but, it won't PC fax
            • JR2ALTA
              • Feb 2010
              • 2033
              Yes it will, you will need extra memory on mfp board. You may be better off telling costumer it won't tho.
              • rrrohan
                • Sep 2011
                • 1977
                Network fax isn't PC faxing? Or do you mean internet fax
