Bizhub 601 with hourglass lockout(CF problem?)
  • axyun
    • Aug 2007
    • 1323
    Bizhub 601 when turned on the hourglass appears in display but nothing. Understand that may be Compact Flash problem where flash may have to be deleted and copied/pasted from another or something like that. I would be unable to do this call. It is a customer of mine and i have been servicing a few other machines for them.
    Customer is in Brooklyn on Eastern parkway and I could go there with someone and pay for your time at a generous rate or a fixed price if you prefer. Of course if part(s) needed that would be extra. Frank/ActionPhotocopy
  • rrrohan
    • Sep 2011
    • 1977
    I had this same fault last week. I replaced cf card and ran cf recovery and updated firmware. You need to re do a few things in service mode and you may need to format HDD and restore address book. Will also lose network settings.
    • JR2ALTA
      • Feb 2010
      • 2033
      It's not something to take lightly, you're correct in looking for an assist. There are critical mistakes that can be made such as formatting. Your card may also be bad, rewriting not as good as replacing card only available through Konica
      • darry1322
        • Oct 2010
        • 817
        Re: Bizhub 601 with hourglass lockout(CF problem?)
        Bizhub 601s also had an issue with the paper lift plates rubbing and shorting the wiring harness under the plate. This would blow inline fuses on the printer control board. I can't remember exactly the test points to look for, but I did have to replace a PRCB with the hourglass syptom.
        • RRodgers
          • Jun 2009
          • 1947
          So maybe pull out all your drawers then try to boot it up as Darry has suggested.
          • darry1322
            • Oct 2010
            • 817
            Trouble is, if they have been shorted the onboard circuit protection has already been damaged. I had a phone support guy tell me which points to check and determined the PRCB was bad. Just can't remember which points.
            • axyun
              • Aug 2007
              • 1323
              Thanks. You guys are great. I won't go unless I have someone with me who is confident on this unit. I will pay generous service rate. Frank
              • axyun
                • Aug 2007
                • 1323
                Don't need it Paul. Thanks anyway. I generally will have the SM +PC before posting but as you know they don't have all the answers or sites like this would not be as necessary. Frank
