C350 Hi yellow toner usage
  • hsjohnny
    • 18
    [Misc] C350 Hi yellow toner usage
    My C350's seem to use a lot of yellow toner lately (last few month's). When I pull the yellow IU's, they always have a lot of toner waste on top of them as well. I have cleaned all of the contacts on the machine's and the IU's well. I have a total of 9 of these things and its becoming a nuisance.
    Any suggestions?
  • RRodgers
    • Jun 2009
    • 1947
    Re: C350 Hi yellow toner usage
    You've ran the stableize I would assume. You can lower how much toner is layed down in tech mode as well.
    • hsjohnny
      • 18
      Yes, I have ran stab and adjusted color in tech mode, but they all seem to use yellow more. It seems as if they go through yellow imaging units more than anything else.
      • RRodgers
        • Jun 2009
        • 1947
        Well, the machine will ALWAYS use a little more yellow when you make color copies, did you try lowering the density in tech mode?
