BIZHUB PRO 1051
  • thuo
    • 155
    BIZHUB PRO 1051
    Hi
    jam at registration section in bizhub pro 1051 ;j-1712 .any idea
  • RRodgers
    • Jun 2009
    • 1947
    Re: BIZHUB PRO 1051
    Remove jam.
    • mikeena
      Branch Technical Manager
      • Mar 2007
      • 219
      Re: BIZHUB PRO 1051
      Originally posted by thuo
      Hi
      if it is a constant my guess would be clutch/ motor
      • Saghir377
        • Feb 2013
        • 47
        Re: BIZHUB PRO 1051
        Dear you didn't mention complete details any how in 1050 paper jam at registration normally low wait if it is low wait paper try to adjust loop from programming
        if it is in thick paper then check clutch but mostly its from registration loop.
        hope this will work.
        • Downunder
          • Aug 2007
          • 174
          Re: BIZHUB PRO 1051
          Make sure the long paper dust (on metal remove-able plate) collector on registration unit is pushed all the way home.
          Also to test if the double feed prevention sensor is working, turn it off with dip sw 26-2 = 1 disabled.
          If this stops your 1712 jams then your sensors are either dirty or faulty. If you replace them make sure you replace them as a pair.
          The copier will work ok with it disabled. depends on your clients requirements etc. good Luck.
          • Rolandito
            • Aug 2007
            • 87
            Re: BIZHUB PRO 1051
            Clean Paper trays clutches...
            Sometimes the paper is not feed at a good speed making a jam in registration unit.
