KM Bizhub C654 Cyan Banding
  • Marsh2
    • 20
    Hi
    Has anyone seen this type of Banding on cyan halftone print service mode 120 level
    Have replaced Cyan iu and Transfer belt Machine has only just been installed so is new.
    Cheers Justin
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 219
    Re: KM Bizhub C654 Cyan Banding
    well after looking at the picture i would say has nothing to do with transfer belt the image problem repeats itself over and over. i was a little confused though is the machine new or is the parts. it sounded like the machine was new. you replaced parts in it and still has problem. key things to try. send your print through stop it before it hits the fuser are the marks still there? i believe (i could be wrong) but the cyan magenta and yellow use the same motor to spend the drums. is this problem occur only on cyan or does it appear on magenta or yellow as well . it could be another developing unit is having issues as the color is spinning it is locking up cause of that color. remove all units and shake them. make sure drum spins freely and not to tough when spins by hand
    • mikeena
      • Mar 2007
      • 219
      Originally posted by Marsh2
      Hi
      Cheers Justin
      were you able to fix the problem
      • knperformance
        • Sep 2013
        • 6
        Has this problem been resolved. I have a C654 doing exact same thing. Replacing the drum unit temporary fixes the issue but the same marks comes back after a few days. Here is the strange part you can take the drum unit that was making the marks and install it in another machine and the marks will disappear after a few days. It is like the drum is getting sunburned. I have replaced drums, transfer belt , roller ,ph unit and relay board ,prcb board as well swapped the erase lamps. My next guess is mfpb as I am out of Ideas. Any help would be greatly appreciated.
        Thanks.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          are the markings drum spacing ?
          Perhaps HV1 is not switching off in a timely fashion.
          • knperformance
            • Sep 2013
            • 6
            The marks are drum spacing . They do not go all the way to edge top to bottom, more just in the middle of the drum.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              if its in a well ventilated area you could try running the machine with the ozone filter insert removed to see if its ozone pooling in the cyan charge unit. The extra airflow will eliminate that . . .
              • knperformance
                • Sep 2013
                • 6
                Thanks, I will try it.
                • knperformance
                  • Sep 2013
                  • 6
                  Any other ideas?
                  • SmellsHot
                    Head Tech
                    • 512
                    Secondary transfer roller possibly. Have you tried adjusting voltages for it?
                    Everyone has the right to be stupid. Some people just abuse this privelage more than others
                    • knperformance
                      • Sep 2013
                      • 6
                      Yes tried that also .
                      • occus
                        • 332
                        If the transferbelt is outside, can you check the position (height) of the IU C, can you see any difference to the other IU's?
                        I had on the 452/552/652 series sometime problem with IU's that make problems on other IU's, maybe change the other IU's too.
                        or sometime i change the IU which also have problems (faulty series)
