Bizhub 750 won't print
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 90
    I have a bizhub 750 that had a C-d203 code. I replaced the image control board and system control board with used from S&S. The machine will now copy but, not scan or print. The data light will blink but that is all. You have to reboot the machine to get it to work again. 1 question I have is, does the CF card hold all of the firmware or just the imagine firmware? Does the rest get stored on the NVram or the IC chip? Can I swap the IC chip with a used one? Could the PRCB board be bad? I am no longer getting the code and The firmware reads it is version 30 or above. Any help would be appreciated!
