Konica Minolta c451 Scanning/Copying PQ issue
  • geemcdoo
    • Jul 2010
    • 28
    Hi Guys
    I have a strange problem when scanning or copying from the platen glass of the c451. The copies will come out with strange burn like marks on them. When I send the same page through the ADF the copies are fine. I've attached both copies (the clean one with the M in the top corner is from the ADF) to give you and idea.
    I removed the glass and done a blank copy and the marks were still present ruling out the glass, I have also cleaned all the mirrors.
    Any help would be much appreciated.
    Regards
    Jaime
  • Max
    • Oct 2011
    • 561
    Re: Konica Minolta c451 Scanning/Copying PQ issue
    Try moving a scanner all the way to the right psn then turn the copier on. See if the scanner vibrates as it moves back, or copy A3. Possibly sticking/missing runner pad on the scanner or some body greased up the runner.
    • sohail nazir
      dear i thing your scanner is miss align from one side or check the charger may be it short.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        yep, scanners bent or not in optical alignment in one way or another.
        • geemcdoo
          • Jul 2010
          • 28
          Thanks Max
          It was indeed a black pad missing off the runner that was causing the problem. I removed the glass, slid the scanner along the rails and noticed that one of the pads was missing from the corner of the scanner assembly. Easy fix, i thought at one point i might have to change the assembly. Thanks again.
