Konica Minolta BIzhub 421 Error C-C192
  • Naveed Shahid
    • May 2008
    • 162
    [Error Code] Konica Minolta BIzhub 421 Error C-C192
    Hello Every One
    I am Facing Problem On Bizhub 501 Error C-C192 I tried to Go service mode But Cant
    ANy Solution
    Regards
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    Re: Konica Minolta BIzhub 421 Error C-C192
    C-C192 Link error (AP2) occurs at the start
    these are what will cause that code
    Extension memory (UK-202)
    Overall control board (OACB)
    if you have the uk-202 remove it and then reinstall it. (Uk-202 Is the i option kit) if problem comes back remove it completly ands see if problem is still there.
    • Naveed Shahid
      • May 2008
      • 162
      Thanks Forr Replyyy
      Dear There Is no (UK-202) Inside the machine one more issue i cant access service mode i try by utility counter but cant
      any other solution dear
      thanks
      regards
      • stevena86
        • Oct 2012
        • 130
        I had a machine that was plugged directly into a wall outlet that was hit by a power surge. When the surge initially happened, the symptom the customer called on was that the copier would not come to ready state, it would get to the hour glass screen on start up and then hang indefinitely. What I found was that the Firmware CF card had become corrupted. I had to order a new Firmware CF card and start at base firmware and version up sequentially from there to the latest firmware. A few weeks after, I apparently had an issue where I forgot to version up the HDD after doing the last firmware upgrade and the machine gave a C-C192 C-C193 error code. I then had to re-do the firmware on the firmware CF card and then re-up the firmware from base again.
        My suggestion is try a new Firmware CF Card. DO NOT FORMAT THE CF CARD! You can pull the old one out of your machine and plug it into your card reader on your computer and see if you can copy all the files/folders off of it. If your card is bad, you won't be able to (I couldn't, which is how I determined the card was bad.)
        If that does not work, I believe your OACB (overall control board) is bad, and will need replacing.
        Best of luck.
        • Naveed Shahid
          • May 2008
          • 162
          Best of luck.
          Thanks For Reply
          Let Me arrange new firmware
          Thanks A Lot
          regards
          thanks
          • Downunder
            • Aug 2007
            • 174
            try the memory board first -- easiest option.
            • Synaux
              • Mar 2012
              • 1224
              Out of curiousity, have you tried getting into trouble reset mode?
              Also, sometimes you can get into service mode by instigating a different error (for example, disconnecting an important cooling fan).
