c650 noise tray 3 y 4
  • raulblanco
    • Apr 2014
    • 8
    Hi
    I have a c650 and generates noise when gets paper trays 3 and 4 other trays no noise. I changed the motor m26 since it is common to trays 3 and 4 but still making the same noise. We have also changed the wheel modules of these trays. It has happened to someone?
    thanks
  • minimerlin
    • 851
    Re: c650 noise tray 3 y 4
    Originally posted by raulblanco
    Hi
    thanks
    Have you had a look at the drive gears at the back of the machine behind the trays..they are where the noise normally comes from, toner and dev from the black IU falls down the back of the copier into this area and the gears clutches etc get covered and wear badly causing the noise!
    Please do not PM me without asking first.
