Scan problem
  • aegington
    • May 2014
    • 13
    Scan problem
    Dear group this is my first post I have been given a c252 bizhub for my business but had a problem with a c-c163 error I have been able to print to the system but have had to erase the error before the c252 will warm up and sit idle now my problem has been one thats only happened since i tryed to find the correct firmware for it and have since upload the firmware 4038-F000-GC4-H5-300_CHECK_SUM-8DD3 but all my scan from the copier have a black border around the end well i say black there black if i leave the top open and white border if i close the top down pictures included i cant find what wrong in such a desperate need to get this sorted and have no idea whats wrong it prints perfectley from the network just wont work properley on copy function i can only think its a firmware issue but as technical as i am im not able to be certain can anyone help pictures included can anyone help the above firmware has been the only one thats worked without getting a c-c163 error
    • 14421
    Re: Scan problem
    That is a really, really long sentence, and very difficult to understand. Maybe if you posted a couple samples it would help.
    • Blizzoo
      • Aug 2013
      • 598
      Re: Scan problem
      I may understand you failed instalation setup instruction after FW update?
      • aegington
        • May 2014
        • 13
        Re: Scan problem
        that is possibly the case i dident do somthing straight after installing firmware again for those who cant make sense of what i put
        Basicley i have a bizhub c252.
        when i got it somebody had tryed to install a newer firmware but it gave error c-c163
        it prints perfectley from the network no problem what so ever the problem is with the copier function ie the scanning bed
        I have installed firmwares of varying versions all have still given c-c163 untill i put on version 4038-F000-GC4-H5-300_CHECK_SUM-8DD3 now i have a working copier without errors
        but i have a page with that perfectley rectangular black center and a white border scan problem.jpg
        This has only happened since firmware update and prior to that i did an nvram reset the machine no long has any errors come up but has this on every scann and copy i make again if i print form the network to the machine its perfect
        Hope this helps
        • Elmo
          • Feb 2010
          • 541
          Re: Scan problem
          You need to set the copier back up correctly
          Reseting the nv ram will have returned values to default
          follow the install instruction as tho it was a new machine
          this should sort out your problems
          I Used To Live To Fix Things Now i Fix Things To Live
          • aegington
            • May 2014
            • 13
            Re: Scan problem
            Thankyou elmo is there any links for a installation manual i assume there is a set of things i have to do first
            if there is a link to any installation manual for this machine i would be greatful i feel like a right plonker
            lesson learned here dont mess with things that are out of your ability lol in a right pickle
            • aegington
              • May 2014
              • 13
              Re: Scan problem
              I would like to just say thankyou for the help i have had all sorted thankyou elmo found a installation manual all sorted first class
