K density faded c550/650
  • Synaux
    • Mar 2012
    • 1224
    First let me just shoot out there that I am well aware of most if not all of the IU fixes/mods/issues discussed on numerous older threads. That being said, I feel inadequate having to post this, but still hopeful.
    There are 3 machines with the same general behavior ONLY on black:
    This scan is not great and a little washed out, but this halftone print (from Service Mode) is perfect on the dark end; however, it exponentially lightens towards the back on the machines/prints.
    HV contacts cleaned, PH cleaned, switched around tranf rollers/belts and fusers. Played musical chairs with the IUs and even manually replenishing toner.
    Ran/reran Reset/Stabilize & Gradation.
    Then I messed around with TCR 3, DMax +10 and ran 250 sheets with almost no coverage and reduced the fade by about 50% on one machine.
    I then installed a new IU that immediately exhibited the same results on the two machines I have tried it in so far.
    At that point it was time to go home.
    Table Numbers:
    VDC-K:
    399 Machine #1
    333 Machine #2
    410 Machine #3
    VG-K
    ~490 Machine #1
    ~450 Machine #2
    ~500 Machine #3
    Level History = Good
    IDC Output = Good
    All machines in a decent environment with ESP protectors (2 machines are at the same location and the other elsewhere).
    Thats about everything my scrambled brain can recall right now.
    Thanks in advance!
  • Rolandito
    • Aug 2007
    • 87
    Re: K density faded c550/650
    I think the IU K is not seating correctly.
    There is a fix for that...Try to give more pressure on iu unit ...
    • mascan42
      • Oct 2008
      • 481
      Also make sure that there isn't developer spilled onto the print head window. I see that A LOT on C550s that didn't have the IU making good contact.
      • Synaux
        • Mar 2012
        • 1224
        Thanks for the reply
        I have the bracket mod installed and even wrapped some tape around them to make them more robust.
        Again thanks for the reply
        I cleaned the PHs.
        I seriously doubt that this is an issue of dirty machines as it is replicated on three machines (and I keep the machines I work on immaculate). Either way, I will remove a PH and inspect it.
        I have not been back yet, but what really freaks me out is that the new IU did what the old ones were doing. I have been thinking about this and the only thing I can think of is that the new IU was an OCE IU chipped for konica; however, the old IUs were OEM konica...?
        Its possible, but three bad HV1 boards...? Possible, but unlikely.
        • Printer People
          • Oct 2010
          • 43
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            stupid question, but are you sliding these iu's in straight out of the box ?
            I've found repeatedly if you do this without agitating the settled contents by rocking / shaking the iu before installation as instructed they fail within a week to a couple days.
            • Etech
              • Mar 2013
              • 3
              Is this the same with the other colours ? if so tbu might be suspect ?
              • Synaux
                • Mar 2012
                • 1224
                Do not shake the black imaging unit"
                I am still unsure to what exactly happened, but I tossed that new IU and swapped the HV board from a parts machine in the first machine I used the black IU in. So far, things are going well...
                • Synaux
                  • Mar 2012
                  • 1224
                  Only on black...color me stupid, but what the heck is a tbu??
                  • Etech
                    • Mar 2013
                    • 3
                    Glad you got it sorted tbu is, transfer belt unit.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Oh lol
                      • GTgosu
                        • Mar 2013
                        • 19
                        i have the same problem so Synaux i try to
                        replace:
                        transfer belt
                        HV board 1/2
                        Toner supply section
                        Developer in IU
                        Drum in IU
                        after that i bought a new IU, after 2k copies problem returned.
                        I don't have any idea how to fix this.
