Bizhub c35 lines on copy
  • Max
    • Oct 2011
    • 546
    Got this Bizhub c 35 with copy quality issue, Had exactly the same about 2 months ago and I had to change the laser and the MFP board to fix it.Never actually got to the bottom of it as laser and the MFP board were changed at the same time. Two months later the same happened on the same copier. Iam sort leaning towards the MFP board and not the laser. Has any one had this before?
    Thank you.
  • HoonBoy
    • May 2011
    • 130
    Re: Bizhub c35 lines on copy
    For sure it's the MFP board. Had this a few times...
    • stevena86
      • Oct 2012
      • 130
      My question is then: What's causing all of your MFPB's to go bad like this?
      • rrrohan
        • Sep 2011
        • 1977
        Mfp. I've had it before
