Konica Minolta bizhub 452 error code C-8102
  • hells666
    • Jun 2014
    • 5
    [Error Code] Konica Minolta bizhub 452 error code C-8102
    Hi i am a technician for ricoh but are company also wholesales sharp,xerox and kyercera.
    I am having a problem with a bizhub c452 that shows me the code c-8102
    w
    i know the problem comes from the adf.
    Since we are not a konica minolta dealer we don`t have the service manual
    the troubleshooting pdf shows this:
    Turn around pressure welding alienation trouble
  • stryder
    • Apr 2014
    • 33
    Re: Konica Minolta bizhub 452 error code C-8102
    I've came up with that code before, if its a DS model, try cleaning the upper rollers. Even if its not, trying cleaning the rollers and look to see if theres any screws or dirt blocking any sensors and clean the adf thoroughly. Then do a trouble reset to see if that solves your problem.
    • Mike.Jones
      Had this error on a c220 recently. Relates to the ADF doc tray lift assay. Solved by cleaning the sensors within, and manually rotating the lifting gear.
      • lilleputte
        • Jan 2013
        • 153
        Howdy
        Clean the sensors and then open the front cover to reset the error code. This usually works for me
        Thanks in advance
        • hells666
          • Jun 2014
          • 5
          thanks guys....
          got time to recheck it today....
          had 5 screws in the adf .........
          i hate screws !!! LOL
          • stryder
            • Apr 2014
            • 33
            Originally posted by hells666
            thanks guys....
            UHUH! knew it, normal problem lol
