Bizhub 131f, MB-190 Message Board Software.
  • Hansoon
    • Sep 2007
    • 3383
    Customer has a Bizhub 131f (Muratec xxx) and lost his CD-Rom with MB-190 Message Board Software. Could not find it on the Internet nor KonicaMinolta Website.
    Any help please?
    Hans
  • ivovb
    • 695
    Re: Bizhub 131f, MB-190 Message Board Software.
    Do You still need driver?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • Hansoon
      • Sep 2007
      • 3383
      Thanks for the offer I got them all.
      What a piece of junk this machine. If you need to scan its hopeless clunky. If you just need a stupid copy it keeps saying "Scanner Calibrating"
      KonicaMinolta has very good machines in the higher regions but all the small A4 stuff is total rebadged crap. Every stupid plastic Brother toy works better.
      Hans
      • ivovb
        • 695
        You are totally right. If I need A4 MFP or printer I'm just offering Brother, HP or similar.
        I found Your thread because I have searching for an issue on BH131f whit registration - no registration at all. Then I found that registration clutch is the same like one on the bypass roller. Next days I'm going to swap them - fortunately user does not uses bypass.
        BR
        • Hansoon
          • Sep 2007
          • 3383
          I'm doing analog copiers, digital copiers and MFP's since unfortunately more than 40 years and had never to replace a clutch. Cleaning, scuffing the plates, reinforcing springs and replacing sticky patches always did the trick. For most clutches it is sufficient to blow them out first with air than soak them with brake cleaner and than blow them dry again. Works in 90% of all cases. Sometimes you have to open them to remove rust and polish the disc and stator. That's it.
          Hans
          • ivovb
            • 695
            I see. Old school. I'm working on office equipment already 17-18 years. So may be I'm a little bit lazy and prefer to change the part whit new one and "forget" about it. Naturally it depends of the price but in more cases it is like that.
            BR
            • Hansoon
              • Sep 2007
              • 3383
              I'm an Indy, I have to pay myself. That's why. If I would work for a large company or boss I probably would also threw parts at machines.
              Hans
