konica C550 code 1101
  • acsolutions
    • Jun 2010
    • 519
    [Jamming] konica C550 code 1101
    hello, the C550 I'm working on has a slight grone and will make 10 to 15 copies then jam with a 1101 code. I swapped out the whole unit with the same occurrence. I see that one motor drives the vertical path roller and the other drives the pickup and feed rollers. I removed the separation assembly and the same noise is there! The noise and jamming does not happen in any other drawer. I checked the gears that drive off the motor and they seem fine! I'm thinking about trying another feed unit, this was a used assembly and did not test before taking it out there! any suggestions would be great! Thanks
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
