Sometimes the duplex unit warps away from the drive gears.
I have had some luck lightly twisting the exit door towards the drive.
Good Luck.
Thanks for the tip. I tried twisting the door earlier but after seeing your tip I reformed up, the plate on the door that hold the drive gears, so that I could ensure that there was a good gear mesh.That solved the problem Thanks!!!!!!!!!!!!
