Konica Minolta C352 error code C5355
  • kibbs
    • Apr 2013
    • 94
    [Error Code] Konica Minolta C352 error code C5355
    hi, friends.. First up all.. i am kyocera mita technician.. i was repairing my friend machine konica minolta C352. this machine has power supply problem. i am swap the board with the konica minolta C252.
    now machine is switchin on. and its showing error Code C5355.
    i dont knw how to trouble shoot. Please someone help to fix the problem
  • stevena86
    • Oct 2012
    • 130
    Re: Konica Minolta C352 error code C5355
    C5355 - Cooling Fan Motor 3's Failure to Turn
    Make sure that when you replaced the boards, you plugged everything back in. Most likely, you have a small CPU fan that is unplugged.
    Good luck.
      • 14756
      I'm not saying it won't work, but the power supply from a C252 is not the same part# as a C352. That could be the problem.
