HP 9850-MFP (Minolta CF-5001) controller firmware.
  • Hansoon
    • Sep 2007
    • 3349
    HP 9850-MFP (Minolta CF-5001) controller firmware. Fiery accepts Minolta's controller CN-5001 (IP921) firmware and shows everything OK after installing but still refuses to boot. Probably is there some interaction between the Fiery firmware and the HP machine firmware causing the Minolta stuff being rejected. Anybody having a solution or the original HP 9850-MFP firmware for that embedded controller? Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • nmfaxman
    • 1702
    Most likely the Fiery system software is corrupted.
    I don't know if it is still available.
