Konica 7022 error f36-2
  • glauberstedile
    • Jul 2025
    Ive got error f36-2 on a Konica 7022 copier.
    The thermisters, thermal fuses and lamps are ok so I don't kwon as do it.
    At the others manufacturers have as reset this problem.
    Haven't got much info on Konica as I usually look after Ricoh kit.
    I would appreciate help from anyone who is more familiar with these copiers.
    Thanks guys. Glauber.
  • Luther
    • May 2006
    • 682
    The procedure has been posted before, look under konica minolta and you should find it, good luck
    • glauberstedile
      yes, but i don't achieve the folder.
      Have you this folder?
