Bizhub 751 phantom drum winding jam on powerup
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Exactly as the title says, it happens every time you turn on the machine or it awakens from power save mode. if you open and close the front door the error is cleared and the machine operates as normal. There is not and never has been paper in the drum cartridge and the drum sensors are spotless.
    Have tried a complete new drum cartridge and have run adjustments again and no difference is made, still does the same thing.
    Anyone had this before ?
    Thinking about trying the printer control board next, or possibly the power supply.
  • Synaux
    • Mar 2012
    • 1224
    Re: Bizhub 751 phantom drum winding jam on powerup
    I dunno--thats kind of screwy--have you tried firmware/cf restore?
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Replacement of the power supply fixed it.
      • Synaux
        • Mar 2012
        • 1224
        Sweet, I suppose that makes sense; thanks for the update!
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Its worth also noting this was a new old stock machine and has done it since out of the box, I suspect the power supply was faulty / maladjusted from the factory.
          Probably why no ones ever seen it before on an existing machine.
          • methogod
            • Dec 2008
            • 921
            what is the jam code?
            i have seen this on 920/950s but it was a code, C code. Not jam.
            depending on the J code... may be simular issue.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              from memory it was a j-2102 or which ever one it was that describes the drum toner density sensor detecting a sheet of paper infront of it at idle state.
