bizhub c250 & c352 transfer assembly
  • goldencup
    • Nov 2008
    • 366
    hi, i would like to ask if can i use the transfer unit assembly of bizhub c250 to the bizhub c352 machine and vice versa? If not, can i use just the belt only? I only have parts guide manual of bizhub c250 and i can't compare it if they are the same. Thank you very much.
  • mdtrinh
    • Aug 2010
    • 68
    Re: bizhub c250 & c352 transfer assembly
    Yes, They are interchangeable without any modification.
    Good luck!
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      I've accidently put one in the other before and it worked fine.
      More interestingly,
      Can you put colour C652 belts into a BW 652 ?
      Colour belts are oddly cheaper and it would save me having to carry both.
      • goldencup
        • Nov 2008
        • 366
        Thank you very much for the replies
        • Blizzoo
          • Aug 2013
          • 609
          More interestingly,
          I'm curious what is the point for those BW mfp's run with transfer belt?
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Because km decided they are not going to engineer black only engines anymore for office machines and they simply now use existing colour engine designs and remove the colour parts. The transfer belt is still required because of the machines origins as a colour machine and the way it works.
            • Hansoon
              • Sep 2007
              • 3391
              Which makes absolutely sense IMHO.
              Hans
              • Blizzoo
                • Aug 2013
                • 609
                I thought somehow improves copying process...lazy engineers
                Sry for hijack the thread
                • rrrohan
                  • Sep 2011
                  • 1977
                  I imagine a 654 colour belt would work in mono version if you made sure the colour transfer rollers were not engaged. Funny the mono belt cost more. Its like the c360 k drum cost more than the colours even though a rechippipped colour drum will work in the black position
                  • Hansoon
                    • Sep 2007
                    • 3391
                    Shrewd marketing or just plain rip off?
                    Hans
                    • habik
                      • 2013
                      Firmwares HERE
                      • CompyTech
                        Super Tech
                        • Feb 2011
                        • 706
                        I like that the design is similar to the color boxes, as I think the the 754 series is way more reliable than the old 751 boxes. And yes the TA8000i is such a piece of crap compared to the 754 boxes. We're replacing all of our old 8000is that have run past 2mil with KM boxes.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          751. Good fun trying to rebuild drum dev and fuser when it dumps toner and you have 1 square metre of floor space to use to work in. 754 is sooooo much better. Doesn't feel as heavy duty though so be interesting to see if it can hit 5 million like I've seen the 751 do
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            754 will be like c652 series, every 2.5 mill replace complete rhs of machine and its good for another 2.5 mill.
                            door, turn over unit, tray 1 + 2 feed units, the guide under the transfer belt, if they are grooved trays 1 and 2, if it has a finisher, the horizontal transport actuator gets worn down too. I also replace the rollers, bushings and clutch for the transport section above tray 4.
