Konica 7222 printing blur when power on
  • KM7155
    • Aug 2008
    • 146
    Hi Guys,
    good day to all.
    i have a 7222 print out very blur only when the machine start up early in the morning.
    the print out will become normal after around 10 copies.
    i have try to change the t/s block, the high voltage casing (at the ADU door), but the
    problem still remain, something wrong with the transfer charges.
    any help will be appreciated.
  • cycle66
    • Jun 2014
    • 13
    Re: Konica 7222 printing blur when power on
    Originally posted by KM7155
    Hi Guys,
    good day to all.
    Have you considered the paper picking up moisture over night and when you get farther down into the stack you are using paper not exposed to moisture? Just something to consider.
    • Luther
      • May 2006
      • 682
      This usually happens in high humidity environments ,or the ozone filter are dirty, remove or clean the ozone filters
      • Flash
        • 378
        Cleaning the drum with alcohol also helps.
        • cycle66
          • Jun 2014
          • 13
          I've had a similar problem with a 7145 in a correctional facility where cleaning the drum with alcohal would help short term. Replacing the drum and blade fixed it. Have you tried new paper to rule out moisture in it?
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            theres a cooling fan next to the ph unit and it has a filter on it that gets clogged, check this also.
            • barratec
              • Jun 2008
              • 162
              Repalcing the drum i've solved something similar.
              • KM7155
                • Aug 2008
                • 146
                Thanks guys for the inputs.
                Yes, this machine is in very high humidity environment.
                i will try to clear the filter first, btw, may i know where is the ozone filter located?
                is it at the back of the machine?
                i have rule out paper moisture as the culprit.
                • Flash
                  • 378
                  There is one on the left side of the machine. If it has a finisher you need to slide it out enough to access it.
                  • Luther
                    • May 2006
                    • 682
                    there is ne above the bypass its for the optics, i usually just removed them
                    • wiliamsclarken
                      3D printing has become very popular and many people are showing interest to do 3D printing by their own.
                      pad printer
                      padprinting
