Operation Check in Different Bizhub Models
+ More Options
Posts
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Operation Check in Different Bizhub Models
    In the C451 Service Manual it indicates an "Operation Check" for motors and clutches in the trouble code section. We have found the sensor check area and the running mode area in technician mode but come up BLANK for actually running a motor! For the life of me we cannot find the area in technician mode to perform an operation check of said motor (M22/M18,M12/M14/etc) You can just run a motor independently in a Konica Minolta right? Ya know to see if it works; like you can with Sharp? Where is it, what is going on, or am I crazy? Is Konica Minolta is just overlooking this ability in some models???!!!???
    Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • Specialist
    • Jun 2014
    • 21
    Re: Operation Check in Different Bizhub Models
    Unfortunately, this model doesn't allow you to perform load checks. You can only see change of states with sensors. You can run it in running mode but that doesn't isolate component areas. This is definitely a minus to troubleshoot problems.
    • Avind
      • Jun 2018
      • 6
      State confimation - > Load check -> 50 / 1
