Faint yellow back ground
  • nezzy2120
    • Mar 2009
    • 13
    I have a Faint yellow back ground on a Konica Minolta C550
  • Synaux
    • Mar 2012
    • 1224
    Re: Faint yellow back ground
    Have you replaced the yellow imaging unit?
      • 14754
      I second this suggestion
      • occus
        • 337
        or try to set background voltage to minus... 2-3... have a look on the life time, is the unit not over the half live try it. save money
        • nezzy2120
          • Mar 2009
          • 13
          I turn down the back ground voltage it worked
          • donrushs
            • Sep 2014
            • 21
            what are the procedures to set background voltage to minus ....2-3? i am an end user and not a technician.
            • donrushs
              • Sep 2014
              • 21
              what are the procedures to turn down background voltage? i am an end user and not a technician
              • Synaux
                • Mar 2012
                • 1224
                We are not here for helpless end users; however, I will tell you that the setting is in service mode and if acquire a service manual, you should be able to find it easily.
                • donrushs
                  • Sep 2014
                  • 21
                  just saw the settings, but dont know how to play with them,and remember english is not my first language
                  • Synaux
                    • Mar 2012
                    • 1224
                    To make the background level foggier, decrease the setting value.
                    To make the background level less foggy, increase the setting value.
                    ^ Regardless, of your understanding of English, simply play with the numbers--you can always change them back if they do not work.
                    • donrushs
                      • Sep 2014
                      • 21
                      okey, i get you, but for my problem,i guess the problem is on the board and need to be replaced, the technician tried to fix the board and all the problem started.
