J10-02 on KonicaMinolta C654
  • gerhardd
    • 12
    Hi
    I've got a Bizhub C654e giving lots of jams on the manual bypass tray at a couple of customers. It happens on all types of paper. Have anyone experienced, and rectified this issue.
    Additional information.
    Customer x so far without success of fixing the bypass jamming issue.
    Initial C654e:
    Adjust separator roller setting
    Tried 2 bypass units from 2 new machines
    Replaced take-up roller with custom made roller.(worked well on the C552 series)
    Had 1 technician and 2 supervisors with me toassist
    Swopped control board and paper feed drive board
    Load firmware ver. E4 and do dipswitch settingfor bypass retry control
    The new swop machine was giving the same jam code J10-02since installation. The latest count is 575 bypass jams in almost 17 000bypass feeds.
    I installed an Inovolt unit (to check power issues) on the machine about 2 weeks agowith no luck.
    No jamming while testing a C454e in our showroom withdifferent paper stock. I used Customer x paper stock.
    No jamming while testing a C654e at Customer y test site withdifferent paper stock. Machine is in an office environment with no bypassprinting.
    Customer z which is a similar printing environment as Customer x. This client has logged afew bypass jamming calls and the jam codes in the management list are the sameas the Customer x
    Customer x
    Thank you
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: J10-02 on KonicaMinolta C654
    I currently also have a brand new C654e that will phantom jam 1002 every single time when only 1 sheet of plain 80gsm A4 is in the bypass tray. It stops at the registration section each time.
    if additional sheets are present to keep the length sensors covered, or if A3 is fed it will not jam.
    Seems a hell of a lot like crappy firmware to me, it is running the latest GD3-E4.
    Going to try a new bypass tray and possibly paper feed driver board if that doesn't fix it.
    Please confirm if yours works with more than 1 piece present.
    • minimerlin
      • 851
      Have a look at the torque limiter on the sep assembly, it will be gummed up and very tight to turn..so poor feed of paper cause of J10 codes. I have hads a lot of these machines give this fault on the trays as well.
      Please do not PM me without asking first.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        new bypass tray assembly fixed the problem on my 2 week old machine.
        still dont know wtf the problem was, i checked torque limiter and it was the same difficulty in turning as the new one and it was new anyway with only 300 pages on the clock.
