c253
  • CrapAimer
    • 296
    c253
    Hi all
    have a c253, think someone has changed the admin password. when I go into the service to change it comes up to verify password then machine completely freezes. Any tips or words of wisdom would be very helpful
    Many Thanks
    George
  • avecosat
    • Jun 2012
    • 304
    Re: c253
    You can change it in service mode .
    • CrapAimer
      • 296
      Re: c253
      that's where it is freezing
      • xscotty1990
        • Nov 2013
        • 40
        Re: c253
        Hi CrapAimer,
        did you tried to update the Firmware?
        Maybe it freezes because of faulty Firmware
        Greetings
        Scotty
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: c253
          if updating / reloading the firmware doesnt fix it, do an NVRAM recovery, that will fix it for sure.
          A less extreme measure would be to try initialise the machine first, this may fix it too - if it cant even do this and locks up, proceed with NVRAM recovery, if it still doesnt work, replace the NVRAM.
          follow the relevent instructions when performing these tasks, you will need to set the machine up again.
          PS. I like your avatar, is this how you deal with office girls who dont use the copiers correctly in Glasgow?
          • CrapAimer
            • 296
            Re: c253
            Only wish full thinking(might stop them sitting on the glass)
            Quite new to Konica stuff how do you initialise the machine, I know on the ricoh you can do a memory all clear is it the same ??
