Bizhub 200 Konica Minolta
  • aldo2405
    • Aug 2025
    [Error Code] Bizhub 200 Konica Minolta
    Hello, I have a problem with my machine.
    Not turn on and the touch-panel shows me these codes:
    Anyone know if the battery problem or nvram or other problem.
    I will be very grateful for any clue to solve the problem.
    • 14790
    Re: Bizhub 200 Konica Minolta
    Almost all abort codes are related to either the MFBS board or the NVRam. I would start with the MFBS. Remember, if you replace the NVRam all your counters will change.
    Hope this helps
    • aldo2405
      Any solution other than replacing the RAM or the IR?
      • stevena86
        • Oct 2012
        • 130
        Are you trying to print a document with a PCL driver? This copier does not support PCL unless the specific firmware has been applied to the machine. Unplug the network cable and trouble reset the machine. If you can get the machine back up without giving the error, plug the cable back in. If the error then comes back, you need to re-do the previous steps as well as clearing out the print queue on all computers/server that print to the machine.
        Not saying that is the problem, but it's one thing I always start with when getting these kind of abort codes on this series of machine.
        I also found this with a simple google search:
        Description
        The machine cycles then indicatesabort code 0x00DC0115.
        Solution
        PROBABLE CAUSES:
        1. Failing MFBS2 board.
        Replace MFBS2 board
        2. Failing BCRS Board.
        Replace BCRS Board
        3. Failing Inverter Board.
        Replacethe Inverter Board
        That is for a Bizhub 282, but they are similar machines.
        • aldo2405
          First showed me these codes:
          I removed the card and IR RAM, cleaned and reconnected and now shows me the codes before I consulted. (0x00DC0115) showed 0x00D82130 before.
          any solution?
          Sorry, I do not speak English, I'm trying to fix it as there is no technician in my area.
          Another question:
          could this be the problem? It is in the FLAT Lamp.
          • emujo
            • Jun 2009
            • 3009
            Both codes are scanner related, I would replace that cable 1st, but the inverter board, or the other 2 boards could have been damaged by the ribbon cable damage. Emujo
