New mini bizhub 4050
  • JR2ALTA
    • Feb 2010
    • 2033
    So out of ten we've had Konica replace 4. They offer no firmware or fixes, they just send us a new one, which is nice, but c'mon did they test them?
    Problems include slow printing, codes, can't wait up from sleep, unresponsive control panel
    Anyone else enjoying these pups?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: New mini bizhub 4050
    Its a konicerised lexmark, it doesnt know wtf it wants to be.
    So far with the rebadged lexys km have been selling, the usual lexmark issues have surfaced already, toner leakage into the machine, failing drum cleaning blades etc, I see nothing has changed from the bad old days when I did lexmark warranty repairs.
    I wonder if out of the box document feeder skew is still 10mm as per when i was working on lexmarks.
    • SmellsHot
      Head Tech
      • 512
      This whole printer exchange thing with Konica is weird....I have a random error that doesn't clear....OK we'll send you out a new printer. I mean that's great and all, but WTF....
      I have about 15 of these out and son of a bitch do they not come out of sleep mode easily. The only trick I've found is hit the power save button twice and that usually does the trick.
      If you haven't noticed this yet. ALL NEW KONICAS are coming with "weekly timer" set to enable. This puts the machine into a forced sleep mode between 10pm and 5am. Just another stupid ass thing you have to learn about from a bitchy customer, cause there machine won't wake up.....
      We are primarily only a Konica dealer, so I'm happy that we can carry a full line, but c'mon....get me something with less issues then your "e" series
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • jotunn
        • 618
        If someone's interested - the older one Bizhub 4020 is clone of Lexmark MX510 and firmware is fully compatible, after upgrade you have still KM branded machine, but upgrade solves some firmware related problems.
        • emujo
          • Jun 2009
          • 3009
          Km does offer firmware updates for these MFPs, but since you are on the OPS program, there isn't a tech assigned to the MFP and, as you said, the box is just replaced if it has a problem. Hopefully, you will get one with the updated firmware. Emujo
          • wseyller
            • Sep 2012
            • 1129
            I spent all week connecting 70 devices for one customer. Mostly 4700p and C3350 Also two C284e and one KIP. I had one instance on a 4700p where it didn't wake up to print. Later tested while in sleep mode no issue. Had on C3350 print fine and then a print soon after it says printer is offline and they had to reboot for it to come back up then it would be ok. Also everything is on IPv6. Email scanning is done on a IPv4 host. So we have the IPv4 IP of each machine set to 169.254.0.0 type IP because they accidently setup their network for a class C /24 subnet so they ran out of IP addresses. I did noticed the weekly timer was already on. I had only one C3350 coming up with a non business hours use and it would shut down at a predetermined time. I hate that you have to config SMTP of the C3350 on the web interface. Also on both devices I've been turning auto acquire setting off after installation because it is slowing things down on every time to connects to the device each time.
            • RichMac
              • 6
              I have one that won't wake up and the service password, 92729272 doesn't work. Any ideas?
              • copyrooks
                • Oct 2013
                • 210
                I would say go to service mode and turn sleep mode on then disable sleep mode on administrator settings and also disable weekly timer settings. If you are unable to get your service mode password you might have to make a call to KM so they can give you the procedure for "cleansing" the machine if at all possible.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  My sincerest condolences.
                  get used to this place, you will be visiting very often.
