We tried years ago to get the Konica Minolta Private MIB and they wouldn't release it to us, even though we are Konica Minolta dealers.
The reason they won't release it to just anyone is because you then have access to the core of the machine and you are able to do things such as reset the meter count, change machine specific information, wipe serial numbers and all sorts of other cool stuff.
What were your plans to use the MIB for in the first place?
Thanks Owl
The customer has some software to poll all of their various printers and report meter readings, supply levels, and a variety of other info. In order to accomplish this they must enter the printer MIB which will cover all functions or an OID for each individual function. This is how it was explained to me. I really have no direct knowledge of this stuff! But it got passed on to me and I am trying to figure it out.
Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers. Now into Ip TV KODI Boxes
Thanks Owl
MIB is part of a SNMP. Check web interface (KM PSWC) - admin log in - network - SNMP. You have to enter information that requires your software.
BR
I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
You don't actually need the Konica Minolta MIB for this as the machine conform to a standard printers RFC meaning you can use a generic MIB to obtain this information. I can't remember the RFC standard to which Konica Minolta devices align with, but I am sure a quick Google search will help you.
Just to get you on track with SNMP, an OID (Object Identifier) is like an SNMP Address where particular information is held within the machine. There are thousands of OID's within the public SNMP community that can be read without using the manufacturers MIB. Below is a link which will show you a simple SNMP structure (with only relevant info rather than all OID's).
Is it required that they have to use their particular software? Because there are solutions already that does this stuff. These vendors have special access to the MIB because they are software developers. We use Print Audit Facilities Manager that will collect meters, supply levels and more. You can also setup alerts for consumables and also create reports. We manage many customers this way and the customer can have access to their own site thru a web login.
