Hi there
I have recently acquired a Konica Bizhub c 20. It kept reporting a paper feed jam and stopped printing unless you opened the right door. This happened very frequently. Usually the paper was not jammed. The error is now permanent and the printer won't print at all.
There is no paper in the system to jam - it is totally clear. It is very dusty inside and also, when it was printing there were lots of ink marks and blotches on the paper. Earlier Gppgle searches have brought up that there is a sensor flag that gets blocked or jams.
Do you know where this could be located please ?
Also do you know how to stop the blotch marks on the printed paper?
Thanks Carl
Thanks Carl
