C353
+ More Options
Posts
  • jonpaul
    • Jul 2014
    • 59
    C353
    We have a biz c353 first it got stuck in warm up,so left it over weekend,came back it now says it has paper jam which is does nt,help.
  • tulintron
    • Jul 2014
    • 668
    Re: C353
    damaged sensor, firmware update.
    https://www.copytechnet.com/images/smilies/cool.pngNada como dia apรณs diahttps://www.copytechnet.com/images/smilies/cool.png
    • Issac-brock
      • Jan 2015
      • 61
      Re: C353
      Any update on this? I just ran into a warming up machine after replacing the print head to solve a C4551 code. Code gone but warming up forever.
      Thanks,
      Colin
      • allan
        RTFM!!
        • 5462
        Re: C353
        reseat it again.
        Whatever
        • laitang
          • Nov 2012
          • 627
          Re: C353
          What's the jam code?
          • Issac-brock
            • Jan 2015
            • 61
            Re: C353
            Originally posted by allan
            reseat it again.
            Will try it, also may do firmware, HDD etc.
            • Blizzoo
              • Aug 2013
              • 608
              Re: C353
              Thanks,
              Colin
              Check the interface cable comming from scanner to mfp for bent pins/poor connectivity
              • habik
                • 2013
                Re: C353
                Thanks,
                Colin
                Have you adjusted the lasers registration? Stabilisation etc.
                I had one 253 that was freezing up..usually over the weekend... no C-codes , just send a print job machine dead...reboot worked fine. This was happening more frequent eventually coming with laser error.
                Changed laser problem gone.
                What about the RAM's have you tried changing it?
                Firmwares HERE
                • Issac-brock
                  • Jan 2015
                  • 61
                  Re: C353
                  Solved.
                  One of the new lasers was defective. After swapping the black and yellow lasers it would intermittently display a yellow laser fault code or say warming up forever. Replaced the yellow with an old unit I saved just in case.
                  Works fine now.
