C2152 in C353
  • tulintron
    • Jul 2014
    • 668
    C2152 in C353
    error C2152 bizhub C353, Help me.
  • ivovb
    • 695
    Re: C2152 in C353
    Did You change transfer belt lately? Anyway check transfer belt if it seated correctly.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • tulintron
      • Jul 2014
      • 668
      Re: C2152 in C353
      BR
      Yes. equipment without the transfer belt. Belt removal of other equipment in operation for testing. then error.
      when Belt return for original equipment works normally
      • ivovb
        • 695
        Re: C2152 in C353
        Check recycle section of belt - if needed disassemble and vacuum clean it. Check if the part with spring on back side of cleaner section can rotate freely.
        BR
        • tulintron
          • Jul 2014
          • 668
          Re: C2152 in C353
          BR
          Thanks...
          • Hansoon
            • Sep 2007
            • 3383
            Re: C2152 in C353
            If the screw of the rear locking latch of the transfer belt is too long this may happen. It touches the white plastic lever underneath.
            Been there done that. One of our colleagues here in the panel gave that hint some time ago.
            Hans
            • jonpaul
              • Jul 2014
              • 59
              Re: C2152 in C353
              We have found that if you back off the rear securing screw solves problem,don t ask me why!!!
              • Hansoon
                • Sep 2007
                • 3383
                Re: C2152 in C353
                That's what I said.......
                Hans
                • tulintron
                  • Jul 2014
                  • 668
                  Re: C2152 in C353
                  Hans
                  The screw is genuine. Installed on both devices the same screw. The tip of the screw is not to prevent operation of the clutch drive merger and second transfer. Its ok
                  With troubleshooting the problem resolves. after a few moments it returns.
                  transfer belt unit reset. On the source machine, works perfect.
                  in another, error 2152
                  • hotfuser
                    • 180
                    Re: C2152 in C353
                    on the rear-side of the transfer belt the actuator is not passing through the photosensor properley.
                    if you pack out the actuator this will get rid of the code and actuate the sensor correctley.
                    • tulintron
                      • Jul 2014
                      • 668
                      Re: C2152 in C353
                      because only one device?
                      In another, no?
                      The same belt in both
                      • hotfuser
                        • 180
                        Re: C2152 in C353
                        In another, no?
                        i get that happen alot it will work in one machine and not the other. There was a bulletin released by KM for that exact fault.
                        If you put the old belt back in does it work?
                        i usually pack it out with afolded piece of paper it works wonders.
                        • tulintron
                          • Jul 2014
                          • 668
                          Re: C2152 in C353
                          Exactly hotfuser. If I install the old addresses.
                          Thanks.
                          I will consult the bulletins.
