Bizhub 350 no display, only orange print button light
  • chejay127
    • Jan 2011
    • 42
    Help guys.. My Bizhub 350 has a problem, My LCD wont display anything(blackout) when i turned on my main and auxiliary switch, the only turning on is the Orange light around the Print Button and its stays orange.
    I have another machine and tried to swap the control panel(lcd assembly) and Nvram but it did not do any good either.. HELP!
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Bizhub 350 no display, only orange print button light
    Could be a faulty MFBS(main board).. Had one with a similar fault before, building got hit by lightening.
    • chejay127
      • Jan 2011
      • 42
      You mean the board at the back of the machine sir? i also notice its fan isn't turning on.
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        The board I'm referring to is under the scanner on the right hand side of the machine.
        Try reseating the connector and the Memory on the MFBS board.
        I think you're referring to the PWB-A board.. I've rarely ever changed that one, however it could be fault.
        • chejay127
          • Jan 2011
          • 42
          Oh that board, the one with usb and ethernet port on it? I tried to replaced it with the working MFBS board from my other bizhub 350 but it still wont work sir T_T.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Maybe rear board, or some kind of power supply problem.
            Sent from my Nexus 7 using Tapatalk
            • chejay127
              • Jan 2011
              • 42
              This morning I tried to replace its powersupply with the one w/c is working from my other machine and the screen boots up and Im about to celebrate T_T but the LCD says :"ERROR!! "
              can't press anything if i put the secondary switch to off the screen is still up I could say its hanging. no codes or anything just "ERROR!!" HELP!
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                Abort code perhaps?
                Because, I don't know of any errors that just state "Error" on that machine.
                • chejay127
                  • Jan 2011
                  • 42
                  no error codes sir just "ERROR!!" on screen and it sounds weird to me too. sigh..
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Its the ram
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1257
                      Does it keep trying to reboot? If so,then sounds like the "error" screen that comes up is the abort screen. Probably corrupt NVRAM.
