C250 intermittent exit jamming
  • copycart
    • May 2009
    • 97
    [Jamming] C250 intermittent exit jamming
    Swapped fusing units, transfer roller unit, cleaned registration, exit rollers, have new feed rollers. Jams on letter R or 11 X 8 1/2. Actually jams in the fuser, paper is about 1/4 the way out of the exit ass'y.
  • avecosat
    • Jun 2012
    • 304
    Re: C250 intermittent exit jamming
    The exit sensor is deformed by heat there is a bulletin.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      exit sensor is part of the fusing unit.
      I assume it was a new fuser you installed, not a old crusty one ?
      • avecosat
        • Jun 2012
        • 304
        There is a reference for sensor only in infohub...
        • habik
          • 2013
          Check the gears for wear at the door exit rollers and also the cogs it mesh with to the top right of the fuser section, spring loaded lever maybe broke. Good Luck
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
