first 25mm or 1 inch for our American friends is faded, but only from tray 4 and only in black mode, colour is fine.
all other trays are fine.
belt, transfer roller and black drum are all new,
fw is at latest level.
fault is exhibited only on the FIRST page, so if you do a multiple page job only the first page is bad the rest are fine. If you power off the machine at the main switch and restart it and do a 1 page job it comes out fine. Let it come to idle state do a 1 page job from tray 4 problem is back again.
if you manually change second transfer voltage settings to anything other than auto, half the page comes out blank.
looking a hell of a lot like second transfer HV failing or delayed start. oddly enough every other tray is PERFECT!!! Anyone had this before ?
