Cleaning Procedure for Developer Units C6501
  • SmokinAussie
    • May 2025
    Hi All,
    Sorry if this is addressed elsewhere.
    I know I need to clean my dev tanks, but I can't find a procedure to clean them safely. I am concerned about damage.
    Can someone please assist with instructions.
    Cheers!
    SA
  • PeterG
    • Jul 2008
    • 177
    Re: Cleaning Procedure for Developer Units C6501
    Hi, fellow Aussie.
    I am not really sure what you mean by "clean the dev tanks". Do you mean empty for a dev change? or are they contaminated?
    • SmokinAussie
      Thanks for getting back to me so quickly.
      The dev tanks are contaminated according to the troubleshooting guide I have.
      It says I need to clean them but does not say how. The procedure does not appear to be covered in the field service manual.
      Cheers SA.
      • PeterG
        • Jul 2008
        • 177
        What exactly is the problem?
        Can you post a sample?
        • SmokinAussie
          Sure I can, but in the mean time, can you advise the procedure. I've already done the diagnosis.
          The dev tanks are out and waiting already.
          Cheers.
          SA.
          • PeterG
            • Jul 2008
            • 177
            I would just drain the dev as you would in a "normal" pm. If you must go further, remove the ATDC sensor. Then hit it with "controlled" compressed air.
            They are supposed to be replaced at 600k anyway.
